Old 09-07-2003, 02:43 PM   #1 (permalink)
SE-R with passing power
Trader Rating: 16 (100%)
Optimal Oil Temps?
Hello,
I was wondering if anyone knew what optimal oil temps were? I have a Setrab Oil cooler installed and currently installing a oil temp gauge. Just wonderign what oil temps should be. If I remember correctly.... they should be around 240 degrees. Please correct me if I am wrong.
'91 SE-R FMAX DET - '94 E Daily Driver - '74 260Z - '05 G35C
Turbo91SER is offline   Reply With Quote
Old 09-07-2003, 11:15 PM   #2 (permalink)
sleeper
I think 240 is too high. I seem to recall one of my friends telling me it should be around 210-220. Hot enough to boil out any water but not too hot.
Khiem
Khiem
'05 Evo
'05 CBR 600RR
Old 09-07-2003, 11:17 PM   #3 (permalink)
Over 180 is good. 200 is great. 240 is on the edge. This is all measureing it in the sump.
Steve
06 G35 6MT
Old 09-08-2003, 08:26 PM   #4 (permalink)
Sounds good!
Well, I got my oil pan back from the welder today. I will be measuring in the sump.
I must have read that 240 was the MAX then...
This is one reason I was asking the experts in here........
Old 09-08-2003, 08:45 PM   #5 (permalink)
I have heard some Z06 guys say that they regularly hit 290F at the track. This may be measured in a different spot. I have heard a range of 240-250F as the upper end of the scale.
