Originally Posted by RedSE-R_T
I have to replace my axles and im considering the 450hp ones from Drive Shaft shop but im not planning on making 450hp with my sr20 only about 250-275hp if i buy new factory axles can i do thew 2250hp without blowing another set of Axles?
-Matt
I have never blow axles on a SR20DE. If you guys would check and see when the CV boots go bad then you could replace them for like $15 and you would not have to have the axles rebuilt.
Cars break their CV axles often when the cars get lowered it puts more stress on the joints and they heat up more also the acordian ruber boot rubs on itself because of the angle of the axle.
You will have the same problem with the ones from Drive Shaft Shop if you do not check your CV boots like every 1000 miles with a lowered car.
Does not take more the 2 mins to look under you car and make sure the CV boots have not poped and lost all their grease from inside the boost the greese will be inside the rim when this happens.
