Old 09-08-2003, 02:46 AM   #1 (permalink)
TSURU corner ligths
Hey Guys!!!!!! i need help with TSURU corner lights, how do connect the wires from the kit if the kit only have to wires and the one from the car has 3? Thanks
schematix is offline   Reply With Quote
Old 09-08-2003, 06:12 AM   #2 (permalink)
I used a voltmeter. If I went to my car right now I would be able to tell you. If you need it asap let me know I will go to my car and check.
F-max stg ll, t3/t4 ballbearing,300zx TT fuelpump,msd digital 6, o2induction stglll IM,intercooler,camgears,UR racing pulleys,JWT program for S-3,waterinjection,race fuel,cobra maf. jwt fuel rail,ES bushingset,Zex flywheel 10.2lbs, ACT clutch, head port/polish with intake bored 1mm and angle job,steel braided brakelines,Arias pistons 8.5.1,eagle rods,80 shot direct port N.O.S. Koyo radiator
boostn92se-r is offline   Reply With Quote
Old 09-08-2003, 11:58 AM   #3 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
There is a write up on nissanperformancemag.com if you want to take a look at that. They have the High and low beem wires mixed, but the rest is correct. the 3 stock wires are turn, constant and ground, the constant goes to the driver light and the turn goes to the corner light, the ground is split to both lights.
Brent
Old 09-08-2003, 06:04 PM   #4 (permalink)
The Groove Master
Rittmeister's Avatar
Click link in sig. Follow links to my Tsuru install, if you want to do it the easy way.
1990 240SR - the DET has landed.
Kent's Funkay Disco
Rittmeister is online now   Reply With Quote
