Old 09-11-2003, 01:22 AM   #1 (permalink)
1995 motor in a 91 Se-R
Alright here we go....I bought a 1995 Se-R and found out it had a serious compression problem.. so I ordered a JDM motor and put that in there. I now have an extra OBD-2 motor sitting around and guess what goes through my work (Capitol Auto Auction) a 1991 Se-R that needs a new radiator and water pump.. I guess when the donator said radiator and water pump he meant a new motor, /shrugs. Either way is it relativly easy to put a obd-2 motor in a 1991 Classic? I am going to atempt it this weekend so anything you guys could do to help would be awesome.
Nissanluver is offline   Reply With Quote
Old 09-11-2003, 01:23 AM   #2 (permalink)
P.S. I bought the car for 35 bucks.
Old 09-11-2003, 01:29 AM   #3 (permalink)
sellout
You want to put in an engine with compression problems? Don't bother, get a used USDM or JDM motor for a few hundred.
93 SE-R- Former BBDET with T28, 13.1 @ 112mph. *SOLD*
whitehawk is offline   Reply With Quote
Old 09-11-2003, 01:31 AM   #4 (permalink)
I know I can just have the head rebuilt later I just want it running my friend is leaving for the Navy... always thought he was kinda gay... but that is besdies the point and we just want to see if it can be done. I think it is the head anyway so I will just change the head over after he is gone I just want to get it running. Any tips??
Old 09-11-2003, 01:32 AM   #5 (permalink)
Sorry I think it is the head that is giving me the problems not the bottom end***
Old 09-11-2003, 01:36 AM   #6 (permalink)
sellout
I still say swap the motor out. Rebuilding the head would be time consuming and a
PITA. Thed later motors are low port and there are differences with the wiring and stuff.
Old 09-11-2003, 11:32 PM   #7 (permalink)
just workin'
its possible for you to do, just make sure that the motor is in good shape first....pull the head and check it out, look and check tolerences....how bout this for an idea, if you are gonna rebuild the 95 anyway why not throw it back in the 95 and swap over the highport jdm into the highport car for less hassle, either way it will work
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
totaled200ser is offline   Reply With Quote
Old 09-12-2003, 01:33 AM   #8 (permalink)
Alright thanks guy I figured it would work just wanted to be sure. :-d
