Originally Posted by Jason
Could this be a possible scenario? I'm a teacher and a coach so I have my keys on a lanyard (those things that hang around your neck like a gym teacher has). When I jumped in my car to go to school on Wednesdayl my lanyard caught on my turn signal arm and tore it completely off! My lights were on and the only way I can turn them off now is to disconnect the battery. If the battery connection wasn't solid then the whining noise could have been my alternator working overtime right?! And, would a bad battery connection cause the care to run that rough? I tightened everything down this morning on a whim and the car runs flawlessly. I feel really stupid. Any input (other then about the stupid part).
If your alternator is fine, there should be no problem running without a battery as I have ran my car without a battery and it ran real well. But if your alternator is not in good condition, the battery can help stabilize the voltage. But I bet in your case, the ground wires for the alternator was loose so your car wasn't forming a strong electrical circuit causing it to run like how it ran.
