While cleaning my throttle body i noticed that my throttle plate dosn't get fully parrallel when i open it. I couldn't find anyway to adjust this though. Is it adjustable?
98' Sentra SE Super Black 5spd
- 91' cam, HS CAI, 17* timing, Redline MT-90, ES Motor & Torque Mounts
- Panasonic Reciever w/ Infinity Components
Mine is like that too. I think that's the way it should be
There should be a little screw thingy that can control how parallel
the plate gets. Have someone MASH the gas and adjust it.
i have adjusted mine on my 92, but you will have to re-adjust your tps (or at least i had to). there was just a hard stop adjustment on where the throttle cable is, IIRC.
92 se-r = 1997lbs autocross bitch
91 se-r = in pieces
92 NX2K = turbo
99 GSXR-750 = downed by a co-worker
yes.. i know.. the question is how much of peeking opening should the throttle plate have at full close position? i believe it should not be air tight closed.
When the throttle is closed there is no air going through the throttle body. The ECU,IACV,AAC and IACV air regulator control the idle
I used to be a noob but now I'm just a dumbass www.m4exhaust.com
