Old 09-22-2003, 03:25 AM   #1 (permalink)
Shift_日産
Weird 58mph or 2650 RPM i think issue
Guys i have been having a kinda odd problem...
When i am Driving down the road at 58-60 mph car runs fine. Have my foot on the gas holding the car at that speed. Well almost the same sopt every day my car looses power for 3 seconds and then comes back to running like normal...
THe problem is When i am driving and it does this i press the gas to try to make it stop and the car still bogs down for 3 seconds or so.
I can down shift into 4th and everything is fine..
So its a RPM issue i am having and only happens at a certin RPM
Like in 3rd gear at 34 mph and close to 3000 rpms 's it does it also but not as bad.
What could be my problem?
Thanks guys if you can help me fix this last problem with my car my 1 year swap will be running right
1996 Nissan 200SX SE-R
クリストファー
•AT-MT B13-LSD swap •JWT P/P •2000SE Clutch Disc •Cusco FSTB •Hyperco Gen2 •Unorthodox 4 Pulley Set •HP Racing Header •Rota 16x7 Circuit 8 w/ BFGs •12Lbs.Flywheel •Injen CAI •Stillen POP Charger •B&M Short Shifter •91 Cam •Prothane Mounts •Magnaflow Muffler •Taylor 10mm Wires •Carbon Fiber Hood •Erebuni Body Kit •Black Healights w/ Amber corners •Redline MT90
AztekSE-R is offline   Reply With Quote
Old 09-22-2003, 03:58 AM   #2 (permalink)
Swap Guru
does it do it in every gear.. *** im guessing MAF.. Check and make shure all your wires are properly connected to your MAF.. happend to me once when i put my intake in and i dident fully plug in the plug to the MAF and around 3k RPM the car would bog down like and the intake would sound like its all covered up.. just my 2 cents.. i could be wrong though.
Kevin
Red200Se-R is offline   Reply With Quote
Old 09-22-2003, 05:12 PM   #3 (permalink)
Shift_日産
ill give it a shot
Old 09-22-2003, 05:20 PM   #4 (permalink)
Coropate greed hater
Also check your distributor.
-The Usual Suspects
Old 09-22-2003, 05:50 PM   #5 (permalink)
Trogdor
it kind of sounds like the problem a car has when it isn't getting enough fuel, though I don't know why it would only do it at a certain rpm
sr20dem0n is offline   Reply With Quote
Old 09-22-2003, 06:32 PM   #6 (permalink)
Tired Greasemonkey
all your tune up stuff has been done, right?
Old 09-22-2003, 08:47 PM   #7 (permalink)
a real egg-head
what about egr... maybe its getting stuck open
-Mike
1992 NX2000, 1998 Honda Civic
60' 1.997 --- 1/8mi 8.387 @ 84.15--- 1/4mi 13.095 @ 103.29 mph
Click here to see my nx2000!
nx2000racer is offline   Reply With Quote
Old 09-22-2003, 11:51 PM   #8 (permalink)
Shift_日産
Well there problem is i have no egr/bpt/aiv or any of that im useing the JDM manifold
Maybe the Fuel Filter???
I have never changed it so but the car has not been running that long sense i have had it
Old 09-23-2003, 12:07 PM   #9 (permalink)
a real egg-head
def. check that... what about timing/octane..
i know when im running 87 on my advanced timing i get a hesitaion here and there.. but with 93/94 its real smooth
Old 09-23-2003, 12:44 PM   #10 (permalink)
Shift_日産
Every tank of gas is 93 with me and im N/a
Old 09-23-2003, 02:44 PM   #11 (permalink)
Shift_日産
well i just installed a fuel filter so lets see if that helps
So far the car runs alot quiter then before and no hesataiton or missing. So lets hope this was my problem
Old 10-27-2003, 01:56 AM   #12 (permalink)
Fat Girls think I'm cute?
It is a fuel problem, I just can't figure out why I'm having the same problem, I changed my fuel filter already!!!!
Crono1321 is offline   Reply With Quote
Old 10-27-2003, 02:07 AM   #13 (permalink)
Shift_日産
yeah the fuel filter had no effect
i have noticed that it does it after i get off of my onramp and get up to speed and hold it at 56 or so. About 5 seconds after that it starts doing what i said above.
Second issue is at 35 in 4th gear i get this like open closed throttle type effect. Like the car's throttle is open then closed open then closed
Old 10-27-2003, 11:03 AM   #14 (permalink)
owned by SE-Rs!
the car sounds like its going in limp mode check the voltage on the two outside wires on the maf, and check the ohms on the middle one.
Nick McCollom
99 Infiniti G20
93 Nissan NX2000 14.027 @97.98 (N/A) I wish I had time and money again, this little car has sat for 2 years now. I do miss driving it bad. It will be back soon though faster than ever.
http://www.cincyclubclub.com/lilly/littlefamily.jpg
sakerocket1 is offline   Reply With Quote
Old 10-28-2003, 12:24 AM   #15 (permalink)
Shift_日産
I checked all of this and such plus I have a badass ground on the maf wire. I mean i get .001 on it.
could it be because my AAc valve? could it be my JDM temp sensor (they forgot to swap it so i dont have a USDM one now). i have almost all my ground regrounded. i have a slightly bad o2 sensor that i get a code on once in a blue moon.
Old 10-28-2003, 05:15 PM   #16 (permalink)
Get a Bosch o2, they're ~$50. Try to swap distributors with another Classic, see if that fixes the problem. You may have a piece of debris inside the distributor (not the cap), or perhaps a bad camshaft angle sensor. Your TPS could have a dead spot in it. At some specific throttle angle the potentiometer could be breaking contact. Check the gap on your plugs, swap transistors/ignitors with a friend, check resistance of the ignition coil.
BTW, I have a 91 SE-R chassis that I'm trying to get rid of. It is in OK shape, the frames stright, the body has some dents. If you want a project car/race car, I'll sell it for dirt cheap. PM me if your interested, I'm located in MD, not a bad commute.
Old 11-30-2003, 06:07 PM   #17 (permalink)
SSS
Guys,
I blocked my EGR (without cleaning it) and still get a slight hesitation in all gears. Did u clean it before blocking the EGR?
dom
SSS
dominic is offline   Reply With Quote
Old 12-01-2003, 02:06 PM   #18 (permalink)
Is your BOV recird? Marcus used to have slight hesitation after shifting before he recir'd. I found out what my problem was...it was the injector grounds on the intake manifold plenum. D'OH!!!!
Justin
S13...fell out of the ugly tree and landed in pieces.
http://www.streetinsanity.com/galler...signature2.jpg
Old 12-01-2003, 02:32 PM   #19 (permalink)
mekanik4life
Could it be the throttle position sensor on the fritz? Good luck, if you fix it, post how you fixed the problem so we know what to look for.
Old 05-04-2004, 09:38 PM   #20 (permalink)
Re: Weird 58mph or 2650 RPM i think issue
did you ever get to the bottom of problem? I'm currently searching for a solution.
-dave
92 Sentra 1.6T
dave_f is offline   Reply With Quote
