Old 09-22-2003, 05:22 PM   #1 (permalink)
should i even try to do it myself.....?
can anybody tell me how hard it is to change a wheel bearing and what to use to press in the bearing? I know my bearing is done for but if its too hard to do myself, then im gonna hit up the shop.
supersik is offline   Reply With Quote
Old 09-22-2003, 05:32 PM   #2 (permalink)
Nitelife's Avatar
I replaced one on my b15 with the help of a friend and without a press. This was a ghetto install but everything works fine. We baked the spindle in the oven for a bit (to expand the metal) and put the bearing in the freezer (to shrink the metal), greased up both parts and then banged it in (using a block of wood as a buffer). If you aren't comfortable doing something similar I'd get it pressed at a shop.
Old 09-22-2003, 06:34 PM   #3 (permalink)
Tired Greasemonkey
easy stuff,at my shop we always use the freeze/torch method
Old 09-22-2003, 06:45 PM   #4 (permalink)
SR20JET POWERED!!!
i took mine to a napa, it was cheap and fast
95 SE-R-SOLD
93 SE-R-RIP(rusted into pieces)
93 SE-R-SOLD
92 SE-R-SOLD
89 Civic drag car
94 G20
Xse-rX is offline   Reply With Quote
