Old 09-23-2003, 01:17 AM   #1 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
Thinning oil problem
I have a slight problem in my car....hopefully its nothing more than slight. Somewhere along the line my car loses about 1 quart of oil about every 3000 miles or so. Its not dripping anywhere, and I don't appear to be burning any.
When my oil starts getting low, my HVLA's start tapping louder and more often then usual and when oil is brought back to normal levels, it goes away almost completely.
The part that really irks me is that after I realize that the oil is low, it usually has a really watery viscosity to it, even when cold. It doesn't have the normal 5w30 oily feel to it. It also takes on a grayish color instead of the normal gold or brown.
I was thinking that maybe I was having some blowby because for a while my dipstick tube has just been kinda sitting in its hole swiveling around. Perhaps atomized oil was making its way out of there? I have recently (last week) JB welded it back into place. Oh, and also my compression is within spec, at 173 in all cylinders. Mods are in the sig.
Some input would be nice, thanks!
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
Old 09-23-2003, 01:27 AM   #2 (permalink)
Seth's Dad
could have a crack in the block and leaking coolant into the oil - is your radiator low?
Chris
2002 G20 Sport - Silver
2003 Olds Mini-Van - say wha????
1997 Corolla - 200+k!!! - Wifeys
MauiBlueGride is offline   Reply With Quote
Old 09-23-2003, 12:14 PM   #3 (permalink)
NismoSER's Avatar
No, coolant is a clean green and never runs low or high. No problems there.
Old 09-23-2003, 02:00 PM   #4 (permalink)
Veritas
SERprise In WV's Avatar
http://www.se-r.net/engine/missing_oil.html
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
Old 09-23-2003, 03:42 PM   #5 (permalink)
He is loosing oil after its filled though. The missing oil thing is just diminished oil capacity.
Old 09-23-2003, 03:47 PM   #6 (permalink)
Coropate greed hater
Read the link Greg posted. That'll tell you where it's goin'.
-The Usual Suspects
Old 09-23-2003, 05:22 PM   #7 (permalink)
NismoSER's Avatar
Yea, seems like mpg9999 understands the problem. I'm not having problems putting 3 5/8's quarts in. I do that after an oil change, and it reads perfectly full. Its just that after about 3k miles, I'm low by a quart and the oil thins to a milky gray watery viscosity. Again, I don't burn any, and I don't leak any.
I do, however, under full throttle above 5,000rpm spew some black smoke from my tailpipe. But AKAIK, black smoke is just a rich mixture, while blue is oil (accompanied by the familiar burning oil smell).
Old 09-23-2003, 05:39 PM   #8 (permalink)
Tired Greasemonkey
the grayish color oil would concern me, maybe do a comp test?
Old 09-23-2003, 07:24 PM   #9 (permalink)
you could always send the oil to blackstone labs to have it annalysed. I think it costs about 20 bucks.
-Mike
Old 09-23-2003, 09:38 PM   #10 (permalink)
i have the same problem in my B14 200sx se-r. i was using organic 5w30, i have 116,000 miles and i kept noticing my oil levels were low, i'm not burning it, and i'm not leaking it. i thought that i was actually thinning it or breaking it down at high rpms.. so i switched to synthetic, the problem is gone.. my oil level isn't going down anymore.. i'm using mobile1 5w30
Howard Houston
AIM - Superbrd15
http://www.imagestation.com/picture/...a/fa2567f3.jpg
IXLR8se-r is offline   Reply With Quote
Old 09-23-2003, 11:39 PM   #11 (permalink)
NismoSER's Avatar
I did a compression test, as stated earlier in the post. 173psi across the board.
IXLR8se-r: switching to synthetic is the last thing I would have thought to do, but if you've had good results with it....I may as well give it a shot. I have only used dino 5w30 since I've had the car....coincidentally since 116,000 miles.
Old 09-24-2003, 03:16 AM   #12 (permalink)
Infiniti Parts Guy
Out of curiosity, have you checked/replaced your PCV valve lately?
Justin McClanahan
2007 350Z
Old 09-24-2003, 11:42 AM   #13 (permalink)
well i thought the same thing.. for weeks i would have someone follow me..i would experiment with different driving styles and have them watch for any signs of smoking.. and there were none. i park my car in the exact same place every night no dripping oil marks, i checked the engine bay for wet spots around maybe the lower oil pan.. nothing dry. it had me stumped for the better part of 2 months. well my oil change time came up and i saw that walmart had the 5 quart jugs of mobile1 for $18 so i figured i'd try it and maybe the slow leak i have will get worse and i'll find it. well i used it.. i've been checking my oil every other day now since then and my oil has not dropped at all.. valve noise is quiet as hell, stays quiet too. i was able to tell when my oil was low before because my cam's were loud. oh well it worked for me man.. thats why my theory is my oil was actually breaking down during high rpms.. synthetics resists breakdown.. i dunno it worked though
Old 09-24-2003, 01:55 PM   #14 (permalink)
NismoSER's Avatar
Yes. I replaced my PCV valve about 5 months ago when I installed my polished valve cover.
IXLR8se-r: once again, you describe exactly the symptoms my car has. I am going to try full synthetic on the next oil change. I'll post my results back here once I have some.
Thanks to all who replied!
Old 09-24-2003, 08:45 PM   #15 (permalink)
Veritas
The 'Missing Oil Syndrome' link was posted so you'd have an idea that our oil passages can sometimes gunk up, causing oil to turn nasty colors. Might have something to do with your situation, might not.
Running the engine oil flush stuff through the engine (the cure for the missing oil) might be a remedy for you.
-GP-
Old 09-24-2003, 11:57 PM   #16 (permalink)
NismoSER's Avatar
Gotcha Greg, thanks for the clarification.
That was my plan, actually. First I was going to run some of the motor flush through. After that, I'll let it run for 3,000 miles more on dino and see what happens. Should that fail, I'll spend the dough on synthetic.
