i was at the drag strip on fri and sat night, and i desided to change the plugs for a fresh set and i notest a wet spot on my second piston from the driver side ( cant remember firing order ) and it was under the intake valve i couldnt smell gass oil or coolent, the oil and coolent level looked fine. so im kinda miffed what it is. all the plugs had a dry carbon coating that looked like it was running to rich. so im thinking a leaky injector or the injector port is not spraying properly and making it drip ? but i couldnt smell gas.
any one else run in to this
