Old 09-25-2003, 06:43 PM   #1 (permalink)
header question, picture inclosed
well i am putting on a gen 2 hot shot header, and i wonder on the stock front pipe there is this metal pipe, that looks like some kind of recirculation pipe, i have a picture, but cant figure out how to post it, if some one wants i can email you.
does that piece just not go back on the new header? becasue there is a plug in hot shot?
willi93ser is offline   Reply With Quote
Old 09-25-2003, 07:34 PM   #2 (permalink)
B15 Bubble
It goes into the side of the header up near the top of it (Closest to the head)? I think you are talking about the EGR, there should be a fitting for it on your new header.
cburwell is offline   Reply With Quote
Old 09-25-2003, 08:16 PM   #3 (permalink)
the one at the top of the header isnt pluged, but the one at the bottom is. which is the other proublem. is there a way to eliminate the egr sh*t, i hear is sucks.
Old 09-25-2003, 08:32 PM   #4 (permalink)
B15 Bubble
Yeah do a search, someone here makes an EGR removal kit that will come with the blockoff plate for the intake manifold and a plug for your header. The only side-effect would be that would would be riding around with an SES.
Old 09-26-2003, 01:08 AM   #5 (permalink)
Making the G breathe hard
Jaketips42's Avatar
what the ell is an SES?
Old 09-26-2003, 01:29 AM   #6 (permalink)
rotorhead
I think he means service engine soon light like CEL. Willi93ser, if the hole that is plugged is the bottom most of the 3 holes, that's for your AIV tube if you have a b13. Just take the plug out and hook it up.
88 RX-7
95 Protege
chris13bsr20 is offline   Reply With Quote
Old 09-26-2003, 01:42 AM   #7 (permalink)
i found some good threads, and i was also told to just remove it. are you sure it is gonna throw a code? from what i have read and what not it will idle better and it wont throw a code or ses.
Old 09-26-2003, 01:54 AM   #8 (permalink)
Import Tech.
The lower pipe is for the Air Injection system, the reason there is a plug is because some years dont have the Air injection system, so on those you just plug it !!
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
Old 09-26-2003, 05:23 PM   #9 (permalink)
B15 Bubble
It may be different for the B13 and B14, but on the B15 no on has found a way to remove the EGR without tripping a code. I know Ian said he had his EGR removed on his B14 SE-R and he had an SES.
