I will be installing a fidanza flywheel and act hd/ss set up soon. i have help on labor,but I dont wanna forget to do anything that could mess up the install. Is there any tips you could give me. i read once about sanding the disc prior to install? I did a search but got tired of sifting through all the useless stuff not pertaining to my Q. thanks in advance, Jason
Sand the disc? I don't think I'd do that. Just remember to out the disc in the right way, i.e. make sure the protrusion the center of the disc is facing the bellhousing.
__________________ "The greatest trick the devil ever pulled was convincing the world he didn't exist".
i forget the reasoning behind it. something like it comes with an anti-rust coating or something. i dunno. well.. is there anything about the install thats easy to miss, or is it just opening up and replacing parts? thanks
No, a Factory Service Manual is a thick-ass book from Nissan. Its a little pricey, but very useful for technical aspects. You can get one from a dealership.
It's funny to read Harris giving clutch install advice. Ha!
If you are speaking to the flywheel, you need to clean it with brake cleaner at the very least. I would also suggest lightly sanding it to get rid of the glazing that might be there---then wipe with brake cleaner. The best is to take it off and have it machined.
The disc itself doesn't need any attention. The only thing I can say is that you need to be sure your hands are clean when you touch it. The last thing you want in there is grease from fingers, etc. That will cause chatter and slipping.
Get an FSM. They're cheap if you plan to work on your car a lot.
I used degreaser to clean my zex flywheel but sanding I have not read anywhere on the FSM to do that. Buy a Haynes manual at the minimum. very easy install IMHO
F-max stg ll, t3/t4 ballbearing,300zx TT fuelpump,msd digital 6, o2induction stglll IM,intercooler,camgears,UR racing pulleys,JWT program for S-3,waterinjection,race fuel,cobra maf. jwt fuel rail,ES bushingset,Zex flywheel 10.2lbs, ACT clutch, head port/polish with intake bored 1mm and angle job,steel braided brakelines,Arias pistons 8.5.1,eagle rods,80 shot direct port N.O.S. Koyo radiator
while still on somewhat the same topic, is resurfacing the flywheel the same as when you get your rotors "turned" (where they carve off a little bit to even out the surface).
If it is, then could you use that method to lighten the flywheel, or is there something special that must be done?
