Old 09-26-2003, 12:09 PM   #1 (permalink)
Fans
Does anyone know if it is possible to wire the A/C fan to come on with the other thermostat controlled fan? I've removed the A/C but would like to have the extra cooling for track use.
Thanks,
Tim
95 M3
05 Pathfinder
http://pg.photos.yahoo.com/ph/tpeele...c0.jpg&.src=ph
tpeele is offline   Reply With Quote
Old 09-26-2003, 12:21 PM   #2 (permalink)
easy 400WHP
Trader Rating: 27 (100%)
Id imagine you could just splice the AC fans harness into the main fans harness and disconnect the original AC signal source.. thats just thinking off the top of my head.. is there a better way??? or can the fans be ran in series? parallel?
~jRod
Originally Posted by Random Genius
"...Everyone in California is easy to deal with, in the mid-west people are so uptight and their first reaction is to get pissy to try and get results. Makes me want to move to California!..."
Old 09-26-2003, 01:12 PM   #3 (permalink)
That's what I was thinking would be an easy solution. I just worry about the current draw. Can the wiring and fuse/relays take it?
Tim
Old 09-26-2003, 02:47 PM   #4 (permalink)
im not trying to be a dick but did you search. im almost positive i have seen a few threads where people had bought aftermarket fans and wired both sides to come on at the same time.
seryusly is offline   Reply With Quote
Old 09-26-2003, 03:07 PM   #5 (permalink)
Yes, I've searched. The best I've found is how to make the A/C fan come on by wiring in a switch. Haven't seen any details on how to wire it to the other fan. I may go the switch option if I can't go the other route.
Tim
Old 09-26-2003, 05:07 PM   #6 (permalink)
easy 400WHP
Been thinking...in parallel the current would remain the same but the voltage would double~not good for lil 12v motors... In series the volatge will remain the same but the current would increase-not sur ehow much of a draw, and if one fan fails, they both will not operate. There has got to be a way to split the signal voltage ONLY to both of them and then give them each individual grounds.....Thats my best guess so far.
