Old 09-28-2003, 01:46 AM   #1 (permalink)
Whut?That Ain't No Hondah
Scans of Wiring Diagrams
Can anyone post/link to wiring diagrams for turn signals? Mine aren't working, and I can't seem to find any diagrams showing how they are run.
If anyone has wiring diagrams for Dashes that would be awesome as well... in particular I need a diagram for the NX1600 digital dash, but a diagram for any dash that has an electrical speedo would probably be helpful.
Thanks!
1990 2+2 TwinTurbo 300zx
1993 NX2000 (JDM SR20DE-T)
1.6 to DET Swap
Engine Removal Writeup
NissanWar.Com - Pick the Nice from Rice
Like Boxing? Check out FightJudge.com
Crim is offline   Reply With Quote
Old 10-21-2003, 03:43 PM   #2 (permalink)
look in any hanes or clitons they are all there.......must not of looked there i hope..i have a over seas manual if u need a copy of that part
sr20mike is offline   Reply With Quote
Old 10-21-2003, 04:35 PM   #3 (permalink)
Pretty Red Boosted B-13
Make sure your Hazard light switch is plugged in, the turn signals will not work if it's unhooked. I can get the FSM diagram, just give me a e-mail addy.
Travis E.
skyliner is offline   Reply With Quote
Old 10-21-2003, 10:35 PM   #4 (permalink)
Yeah I figured this out by chance, i had the NX gutted, and when i started putting pieces back in I found out the hazards button has to be plug'd in.... good thing i didn't toss that piece of the interior.
Old 10-22-2003, 01:28 AM   #5 (permalink)
little Thunder
nismo91's Avatar
Travis E.
Damn! This is good info... I did not know this. When I test drove my SE-R I didn't have the center console on. So the turn signal did not work. I thought that's another piece I have to troubleshoot.
THANKS GUYS!...
Oh' I have the FSM as well if you need me to copy a page or two.
Steve
= Steve Lotho =
= = 91 Classic = =
= = Forum Rules = =
nismo91 is offline   Reply With Quote
Old 11-08-2004, 06:23 PM   #6 (permalink)
just bought a nx2000, hazards and turn signals don't work . fuse for the turn signals isn't blown, nor are any other ones. also, interior arrows don't blink when turn signal is turned on. i do have 2 plugs that aren't hookeed up to anything in the console under the radio, couls thing be something ? i can't see or feel where it should plug into. help. thannks
'95 200sx SE-R : JWT Pop, Top Speed Header, HKS Super Drager cat-back, Highport Intake cam, 17* Timing.
1993 Classic All motor goodness. -Sold
1991 NX2000 I/H/E. - Sold
1993 NX2000 I/H. - Running strong on swap # 2, For Sale
1987 Mazda RX-7 SE. -Intake, downpipe, pre-silencer,
cat-back exhaust. Also for sale.
hondaeat-r is offline   Reply With Quote
Old 11-09-2004, 12:28 AM   #7 (permalink)
Well just check the hazard switch. The plug for it won't fit anything else. I too can scan pages from the fsm if needed.
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 11-09-2004, 10:33 AM   #8 (permalink)
that'd be awesome if i could see that diagram. also, i do have 2 plugs hanging free behing the steroe & climate console. one's square and white, the othr more flat and black. if i recal correctly, the rear defog, hazards and turn signals don't work , not even any blinking arrows or noise in the gauge cluster. thanks a lot
Old 11-10-2004, 07:43 AM   #9 (permalink)
nx vet
pull the beauty ring that goes from over your vents to the shifter those plugs are your hazard and defroster u plug them in and everything will work u could also pop out the buttons and plug them in
my93nx is offline   Reply With Quote
Old 11-10-2004, 10:43 PM   #10 (permalink)
got it, thatnks guys, all is well
