Old 10-10-2003, 08:13 PM   #1 (permalink)
Gone V8 Hunting Lately?
Cluster Lights crapped out
Last night my cluster lights were working. I hooked up another autometer gauge to my dimmer switch and they all worked last night. I get in the car today and turn on the lights and nothing, the HVAC and every other light that is controled with the dimmer is not working. I check all the fuses under the dash but they all looked good. I tested the plug that goes into the dimmer switch and it isn't even getting any power when I turn the lights on. Anyone have any suggestion on what I should look at or test?
Thanks
1997 Nissan 200SX SE-R
1F@$t9d7 is offline   Reply With Quote
Old 10-10-2003, 09:25 PM   #2 (permalink)
You blew your dimmer switch
Oochie
beataholic is offline   Reply With Quote
Old 10-10-2003, 10:38 PM   #3 (permalink)
Red line chaser
I'll second that.
96 SE-R: SR20VE - bolt-ons
97 SE-R: GtiR - getting there - need $$$
03 Altima SE V6: alarm+remote start/Pioneer TV+DVD/MB Quart comps/US Amps TU-4360/Stinger blocks, Expert RCA's, and 0 gauge wiring/rest of system going in shortly
WickedSR20 is offline   Reply With Quote
Old 10-10-2003, 11:20 PM   #4 (permalink)
I can unplug the dimmer switch and test the plug and it isn't getting any voltage. I think it has to be somewhere before the switch.
Old 10-11-2003, 03:16 PM   #5 (permalink)
Genetic Freak
Check your R tail lamp fuse. You may have blown the fuse that is linked to your dash lights and parking lights.
The Sandman is offline   Reply With Quote
Old 10-20-2003, 06:19 PM   #6 (permalink)
banned
i had a similar problem also, just checked the first fuse coming off the battery, its completely melted, ill try to get a picture up of it
cantdoadonut is offline   Reply With Quote
Old 10-20-2003, 11:43 PM   #7 (permalink)
P10 Geek
Sounds as if your taillight fuse is blown or your fusible link up near the battery fuse block blew.
Brandon
'02 Maxima SE 6MT
'96 G20 (SOLD)
