Old 10-11-2003, 07:43 PM   #1 (permalink)
Did a JDM Swap? Someone Help!! #2
I did a SR20DE JDM swap in a 98 sentra GXE. The harness was bad it was a 94' se-r.I could not find another one.
1) So now I have a 94' G20 ECU+Harness, But it wont work on the Fuel rail.Also I don't know how the injectors plugs look on the harness. Can someone give me a Pic.
2) Or should I buy A jgycustoms Fuel Rail and 50# injectors and rewire the injectors to the Harness to make it work. When I find how the wires look.
1990 S13 coupe
jsentra is offline   Reply With Quote
Old 10-12-2003, 11:39 AM   #2 (permalink)
switch to iacv wires around and the two wire left over u dont need theyre extra sensors wires for a us motor
sr20mike is offline   Reply With Quote
Old 10-12-2003, 08:27 PM   #3 (permalink)
I'll try it today, THANKS.
Old 10-16-2003, 08:29 PM   #4 (permalink)
It did not work.Still when i start the engine the thing starts to rattly alot, but when I unhook the the mass air flow sensor the engine runs strong. But burns gas like crazy. what should I do.
Old 10-16-2003, 09:57 PM   #5 (permalink)
fartin dust
When ya unplug the MAF with the car running your putting the ECU into limp mode. Try checking the codes on the ECU and resetting it. Also check for vacume leaks.
I used to be a noob but now I'm just a dumbass
www.m4exhaust.com
james vick is offline   Reply With Quote
Old 10-18-2003, 01:27 PM   #6 (permalink)
OK will try.
Old 10-19-2003, 05:38 PM   #7 (permalink)
still no luck.
Old 10-19-2003, 07:39 PM   #8 (permalink)
shift_boost
what codes is it reading? there are about 3 diff plugs that will plug in wrong.
myspace
95 chevy dually big, black, low, and diesel
twisted200ser is offline   Reply With Quote
Old 11-04-2003, 08:24 PM   #9 (permalink)
New problem
