Old 10-12-2003, 10:45 AM   #1 (permalink)
Nos Slut
Is this a sr20de ECU or a ga16de?????
The Ecu I have says:
5ZE1JT
JT
JA1BL77 BW7 8413
Can anyone help?
95 200sx SER
PS Header w/ 2.5" Collecter| 3" Intake w/ POP| 2.5" Exhaust w/ Cherry Bomb Pro muffler| ES Bushings| NX2000 Sway Bar| 91 Intake Cam| G20 Ecu
96 Sentra 1.6(B13)
Lightend stock flywheel| ACT HD PP w/stock disc| UR Crank+PS Pulley| 3" Intake w/ K&N Cone| XS Power Header| ES Bushings| ST Sway Bars| 2" Exhaust w/ Magnaflow Muffler| 60mm TB| Intrax Springs| 50hp Shot NOS
HaulinSentra is offline   Reply With Quote
Old 10-12-2003, 04:50 PM   #2 (permalink)
The Sky's The Limit !
any other numbers on there?
P11GT is offline   Reply With Quote
Old 10-12-2003, 05:56 PM   #3 (permalink)
Nos Slut
sorry thats all the numbers/letters off the ecu
I am pretty sure its a b14 sr20 ecu, but I just want to make sure its sr20 not ga16!
and is it mt or at?
Old 10-12-2003, 05:58 PM   #4 (permalink)
sorry i dont recognise any of the numbers.
Old 10-13-2003, 05:04 AM   #5 (permalink)
SE-R GREEK
Does not look like an SR20 ECU.
Way different than the #s on mine.
Best you could do at this point since you already have a GA16 in YOUR car, is check the #s on your own ECU on the car.
Chris
Old 10-13-2003, 01:41 PM   #6 (permalink)
SPEC V'in It....
If it was a B14 it would say that on it, well mine does
YES SER is offline   Reply With Quote
Old 10-13-2003, 02:52 PM   #7 (permalink)
Nos Slut
I do know that this ecu will not plug into my b13 ga16 harness, but does plug into a b14 ga16 harness! Will it also plug into a b14 sr20 harness? or since it does plug into a b14 ga16 harness and maybe not a b14 sr20 harness, it could just be a b14 ga16 ECU?
does anyone now if a b14 ga16 ecu will plug into a b14 sr20 harness?
if not I guess I have a ga16 ECU, not a b14 sr20 ECU
