Originally Posted by nx2thousand
1. Do the two mounts that look almost identical both go into the passenger side or is on one of them for the drivers side?
2. Does worn mount on the drivers side need to be removed or is the es mount pressed into the the worn mount?
You got it all wrong. The two circular inserts are for your crossmember mount. The other cylinder insert and ovalish insert are for the dog-bone torque mounts. That kit has no inserts for your passenger or driver side mounts.
