Old 10-13-2003, 10:53 AM   #1 (permalink)
Irish carbomb destroyer.
JDMsr20 with US mount
ok im about to finish up my swap ... 1.6 to JDMsr20...my question is...how can i get the US SE-R motor mount to fit on the JDM block? the mounts bolts are to close together to bolt into the block :/
The CultClassic
circa.13 is offline   Reply With Quote
Old 10-13-2003, 10:55 AM   #2 (permalink)
oh and also ... same problem with the front bracket next to where the AC went to...the SE-R's bracket its to small to bolt onto the block
someones gotta help...ill even throw in some icecream @>
Old 10-13-2003, 11:48 AM   #3 (permalink)
Whut?That Ain't No Hondah
Hey check the link in my sig. You gotta get USDM Sr20de mount BRACKETS for the passenger side, the rear mount BRACKET, and the front mount BRACKET.
1990 2+2 TwinTurbo 300zx
1993 NX2000 (JDM SR20DE-T)
1.6 to DET Swap
Engine Removal Writeup
NissanWar.Com - Pick the Nice from Rice
Like Boxing? Check out FightJudge.com
Crim is offline   Reply With Quote
Old 10-13-2003, 12:02 PM   #4 (permalink)
use the us frame on the jdm engine and then use us mounts, surprising they are different esp the front and tranny
Dave
Dave Deen is offline   Reply With Quote
Old 10-14-2003, 08:39 AM   #5 (permalink)
got it fixed went to NismoRob and he hooked me up with the US brackets worked like a charm..thanks for the help fellas just few more steps and the GA to SR will be finished
