Just as the subject says, I'm looking to do this on my '91 SE-R. I went to Auto Zone / Pimp Boys / Advance and they all had the same tools to check fuel pressure. One says its ideal for domestics with a Schrader valve (like my '90 Firebird
) and the other is a generic tester that also checks for vacuum (and is about $10 cheaper). Which one to get? And where do I do the test from? The fuel line from the filter to the fuel rail? Somewhere off the fuel pressure regulator? I also have a fuel sample port for roadracing -- basically a "T" fitting off the fuel line between the filter and rail ... looks like it has some kind of valve on it.
Edit: AFAIK, the FSM is pretty vague about this procedure. All I could find is a short paragraph on what the fuel pressure should be. Nothing about "how to."
Pat
'91 SE-R, not much faster (if at all) than ITB VW's and BMW 2002's
