Old 10-13-2003, 10:46 PM   #1 (permalink)
how does sr feels with tooth skipped in cam install
how does sr feels with tooth skipped in cam install?
how does a car drive any signs?
i know it is much slower
and yes id did search
3BiP is offline   Reply With Quote
Old 10-14-2003, 12:39 AM   #2 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
When mine skipped a tooth when I put my tensioner in, it ran like crap, like it was missing really bad.
- Rob
Old 10-14-2003, 01:14 AM   #3 (permalink)
please be as detailed as possible
did you car fee like something is holding down you rpm guage when you floor it
Old 10-15-2003, 02:15 PM   #4 (permalink)
How much difference does one tooth on the intake or exhaust sprocket make. I estimate it to be 360deg/36teeth=10deg per tooth. I see people adjusting their cam timings by 3-5deg with the adjustable cam gears so I really don't think 1 tooth off will make that huge of a difference. I think it depends on which side you skip the tooth that would determine how much power loss you get. Correct me if I'm wrong.
99SE-L is offline   Reply With Quote
Old 10-15-2003, 02:48 PM   #5 (permalink)
Master Cunnilingust
1 tooth makes a big difference. When mine skipped a tooth on the exhaust (the only place the chain can skip mind you) when I put my tensioner in, the car was missing terribly.
Old 10-15-2003, 06:27 PM   #6 (permalink)
BOOSTIN AIN'T EASY!
car ran like sh*t and would not rev over 5800, and at night I popped the hood after driving and the exhaust manifold was glowing red, so I am assuming it was running really lean.
Richard
THE CREW IN THE DRIVE WAY
96 200sx=249whp@10psi (t28, s3, 370's@4bar, motor mounts, 3"exh etc.etc. etc.
03 350Z <--WILL GET SMOKED BY THE 200 @ OR ABOVE 10PSI
05 Altima 2.5s
93 geo prizm
86 toyota celica (22re RWD) <--FUN AS HELL TO DRIVEhttp://www.sr20forum.com/img/data/50.../DSC009261.JPG
bickricksr20 is offline   Reply With Quote
Old 10-15-2003, 07:25 PM   #7 (permalink)
Yes Dear.
damn.... i remember..
mine had this awful tickin sounds when i punched it..
and i was scared to go passed 4500... i dont know.. i just had no power.. it was so power less i couldnt keep up with a civic dx
Sr20kidD is offline   Reply With Quote
Old 10-15-2003, 09:43 PM   #8 (permalink)
I hate 240sx owners
check your fuel filter if its never been changed...
Raze: To destory, demolish, obliterate.
Project RaZe: The ongoing effort to destroy, demolish, and obliterate the competition.
RWD SR20DE 93 240SX Coupe.
Best all Time Quote:
FWD should really be spelled FTW
NissanTuner is offline   Reply With Quote
Old 10-15-2003, 09:54 PM   #9 (permalink)
Pimp Sh*t
Richard
Mine did the same thing, but I'm still not absolutely sure what caused it because me and 3 other people (eric96ser, calum, and bowlcut) counted the links. Now the same motor with the same timing chain and links is running just great in a turbo car and I helped him put it in .(sorry to get off topic)
Murfreesboro Sleeper Street Sweeper
91 SE-R--lots of mods SOLD
The Wolf
01 Jetta Wolfsburg 1.8t--APR 93/100 oct chip, TT 2.5" Downpipe, Forge 007, n75j, custom intake, votex springs
b13speed is offline   Reply With Quote
Old 10-15-2003, 11:32 PM   #10 (permalink)
banned
yeah, my car ran slow, and sounded like a truck. I took the intake cam out and re-installed it more carefully and it ran fine after that.
JDM_2ner is offline   Reply With Quote
Old 10-15-2003, 11:34 PM   #11 (permalink)
Why do you say it's only possible to skip a tooth on the exhaust side?
binky is offline   Reply With Quote
Old 10-16-2003, 09:53 AM   #12 (permalink)
G-G-G G Spot
when my cams skipped a tooth, the idle and response was horrible.. and when i checked the ignition timing it was way lower then stock; i then FULLY advanced it and it was at 10 degrees... it ran pretty bad.
-white '91 sentra se-r, 200SX SE-R transmission, new clutch, pacesetter short shifter, pacesetter headers, custom cold air intake, Courtesy Nissan/Topspeed stainless steel cat-back exhaust, BKR6's, UR 2 pulley set, advanced timing, eibach pro-kit-
T28 Project^
SERawr is offline   Reply With Quote
Old 10-20-2003, 09:07 PM   #13 (permalink)
I can spell you.....
After reading through this thread, I'm worried my prob my have to do with missing a tooth? My car is running perfectly fine though (no power probs), it's just when the car is idling in gear, and has no gas..
See here:
http://www.sr20forum.com/showthread....896#post491896
chucky200sx is offline   Reply With Quote
