I have tried almost everything.....
I have replaced: Radiator, thermostat, radiator hoses, heater hose, fuses/relay, radiator cap, and now I have even short-term wired my fans to a toggle switch that I can control myself untill I find the culprit behind the problem. I cant stop boiling over out of my overflow. I dont break 210 deg., so whats the problem? My factory temp gauge dosen't go past the half way mark so all I can think of it being is the factory temp sending unit. ?? Josh
EDIT: If it matters much, its a bb swap b13. The radiator is a NX unit. Something else that may be related, when I first noticed the overheating, I also noticed that there is a noise under accelleration that sounded like a rod at first, but after sticking my head out the window to listen it sounds like a boost leak. Kindofa fluttering tick that stops after 5 min. of driving. Thanks in advance, Josh
I guess I should also add that the fans would not come on, even with the a/c on.
-Bill Hicks
