Old 10-15-2003, 08:33 PM   #1 (permalink)
TOB clip put hole in bellhousing...how to separate bellhousing
little clip from the TOB, somehow popped off, tumbled around inside the bellhousing, and got mangled up and punched a hole in the gear side, causing the fluid to leak in, not the seal I though it was at first. Going to see about getting it welded up tomorrow.
How do you get the bellhousing off the rest of the tranny? I pulled the bolts off but couldn't get it apart, just separated a little, is there anything holding it back on the input shaft? Be easier to take than the whole tranny.
gah, I need a FSM, probably buy one with my next paycheck
Thanks for any help.
Mirage is offline   Reply With Quote
Old 10-16-2003, 05:40 PM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Stop right there without a FSM. Don't even attempt to open the case without some sort of manual. There is a C clip that holds the top case to the gears, and it sounds like you forgot to take that off. Its under the circle cover that is held on by 8 or 10 bolts. Its the big C clip, not the small one. It might be covered with oil.
1991 Sentra SE-R
The community is here.
Old 10-19-2003, 12:41 AM   #3 (permalink)
TT Tuning
got a ? is a none lsd inner case the same as a lsd trany? i know the outer is differnt.
91 se-r the key is still stock. SOLD
http://img.photobucket.com/albums/v2...e-rpics025.jpg
http://img.photobucket.com/albums/v2...frontangle.jpg
01 dodge cummins 460/930 sold
03 dodge cummins ???
08 maxima stock
afstegg is offline   Reply With Quote
