I bought the NX with what I thought was a blown headlight bulb. Next day I looked at the bulb and it was still good. I was not able to figure out the problem, the fuse for it is still good, not blown. What should I check for? Right now I spliced the bad harness into the working one, and I have both lights. I put a bigger fuse for the right headlight, just to make sure it wont blow right away with double to power going to it.
Also, the foglights dont work. I know on the classic, I would hear the foglight relay click when pressing the button. But I dont hear any click on the NX. On the classic, the relay was located on the firewall, but the nx appears to have it in the relay box next to the battery. I have not taken the foglights apart to check the bulb, but tried 2 other foglights, and they still dont work. Does the NX have a foglight fuse as well, I know the classic did.
If anyone has any input, please let me hear it
