Old 10-16-2003, 12:44 AM   #1 (permalink)
What is this hose?
Can anyone tell me what this hose is (the one pointed out by the red arrow)? It's not plugged to anything.
99SE-L is offline   Reply With Quote
Old 10-16-2003, 01:58 AM   #2 (permalink)
stirring but plain-faced
I think a better pic may help it finding out what the hose is for.
NoClassic is offline   Reply With Quote
Old 10-16-2003, 02:12 AM   #3 (permalink)
I believe that hose is called the oil in the intake manifold hose...
2SR20DE is offline   Reply With Quote
Old 10-16-2003, 12:41 PM   #4 (permalink)
just workin'
it is just some sort of emissions vaccum line, i have two of them open, depends on your emissons setup, i believe if you look under the intake manifold, you will see that it is a bracket with 3 tubes mounted on it, unless you have vaccum going into it you don't need it going out, hope this helps some
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
totaled200ser is offline   Reply With Quote
Old 10-16-2003, 01:57 PM   #5 (permalink)
bla bla bla
you don't use it, don't worry about it, I had mine unhooked when I had "Black Beauty" (my 98)
2003 VW gti 1.8t
72 Datsun 510-sold
Old 10-16-2003, 02:35 PM   #6 (permalink)
Did you unhook it yourself? When I saw it, I was afraid I might have a vacuum leak so I plugged it.
Old 10-16-2003, 04:25 PM   #7 (permalink)
I'm guessing we're not talking about the one going into the intake... oops...
Old 10-16-2003, 04:52 PM   #8 (permalink)
I left that one unhooked too. What is it for?
Old 10-16-2003, 04:55 PM   #9 (permalink)
Coropate greed hater
My guess is that its the hose that connects the intake to the EGR system, or more specifically, to the BPT valve. Looks more like a nipple to me than a hose. You should take a clearer pic.
Old 10-16-2003, 06:27 PM   #10 (permalink)
The one coming from the front of the car... the larger one... it's a warm air return line. Not needed. I don't think any aftermarket intakes utilize this... I put a breather on mine because my header still utilizes the aiv and therefore the warm air return also...
Old 10-16-2003, 10:29 PM   #11 (permalink)
The big hose, I thought was for crank case ventilation. It is utilized by both the Place Racing and AEM cais. I'm referring to the small hose on the bottom of the intake pipe.
Old 10-17-2003, 02:35 AM   #12 (permalink)
Well... the big one in your pic... that's for crankcase vent yes... I'm talking about the one coming off near the aiv unit to the stock intake... you wouldn't have this piece if you have a hotshot... I don't even know if your year had that or not so who knows.
Old 10-17-2003, 03:50 AM   #13 (permalink)
so would that be the small hose on the intake pipe which you are referring to? Since there are 2 big ones and 1 small one.
