Old 10-16-2003, 02:06 AM   #1 (permalink)
TT Tuning
problem with digital 6
has any one had problems with the digital 6? hit around 4-4500 rpm's and it starts miss firing..no its not the rev limiter set at 0 for the max and 0 for 2 step.
heard of drilling hole in cap. the cap and rotor are 2 months old nissan wires with stock nissan wires.
thanks for any info
Tim
91 se-r the key is still stock. SOLD
http://img.photobucket.com/albums/v2...e-rpics025.jpg
http://img.photobucket.com/albums/v2...frontangle.jpg
01 dodge cummins 460/930 sold
03 dodge cummins ???
08 maxima stock
afstegg is offline   Reply With Quote
Old 10-16-2003, 11:17 AM   #2 (permalink)
Veritas
SERprise In WV's Avatar
Trader Rating: 17 (100%)
Have you tried opening the gap on your plugs? The added ignition power means you can run larger gaps with a turbocharger/nitrous.
Also...make sure the D6 box is set for 4 cylinder operation (I know, but just double check to be sure). Also...is there one wire that is uncut and makes a complete loop, coming out of the box?
If not...that's your problem. Per MSD...there is one wire that should not be cut.
New box, or used?
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
Old 10-16-2003, 12:38 PM   #3 (permalink)
Trader Rating: 36 (100%)
I believe Mike K. had problems with the digital 6 in the highport motors. I think we swaped it out with a Crane and everything was fine and dandy. Make sure you have good ground connections. just curious, did you relocated your battery?
99 sentra se-l
t25 turbo part out:
http://www.sr20forum.com/forced-indu...isc-parts.html
iczer200sx is online now   Reply With Quote
Old 10-16-2003, 06:05 PM   #4 (permalink)
TT Tuning
YEA MY BATTS IN THE BACK..AND ITS A NEW BOX
Old 10-16-2003, 06:09 PM   #5 (permalink)
easy 400WHP
Trader Rating: 27 (100%)
My Digital 6 + works fine in my highport. Defintiely check the settings.. thats the only thing it can be, besides any obvious ignition problems (bad plugs, etc)
~jRod
Originally Posted by Random Genius
"...Everyone in California is easy to deal with, in the mid-west people are so uptight and their first reaction is to get pissy to try and get results. Makes me want to move to California!..."
Old 10-16-2003, 07:45 PM   #6 (permalink)
Stuck on an island
MSD has bin giving out allot of faulty units of late, i have known several people that have received bad units. might want to look in to that.
279 hp @ 17psi
Nx 2000 : It sticks to the road like bubble gum to hot asphalt
Nick is offline   Reply With Quote
Old 10-24-2003, 01:44 AM   #7 (permalink)
TT Tuning
so how many of you have the dig 6? wear is it mounted and how long has it been hooked up.
Old 10-24-2003, 10:13 AM   #8 (permalink)
original battery setup has the ground cable connected directy to the tranny case from the battery, then block to chassis. you might have to run a (-) cable all the way from the relocated battery to the tranny case to eliminate any ground loops. call up jwt and ask them about the digital 6 issues with the highports.
