Old 10-16-2003, 07:01 PM   #1 (permalink)
Yeah thats plenty right.
Running at full advance
My car will not run normally at 17* timing. It feels as if it has zero power. So in order to feel as if the car is semi normal I have to run at fully advanced timing. I had cams put in and then I put the stock cams back in. I feel as if something is going on inside the motor w/ timing. What could be the problem?
96 200SX SE-R: I/H/E, B&M SS, Black Kosei K1's, ES Torque Mounts, RSTB, and suspension stuff... (SOLD)
animalbarrie is offline   Reply With Quote
Old 10-16-2003, 07:45 PM   #2 (permalink)
owned by SE-Rs!
you skipped a tooth on the timing chain
Nick McCollom
99 Infiniti G20
93 Nissan NX2000 14.027 @97.98 (N/A) I wish I had time and money again, this little car has sat for 2 years now. I do miss driving it bad. It will be back soon though faster than ever.
http://www.cincyclubclub.com/lilly/littlefamily.jpg
sakerocket1 is offline   Reply With Quote
Old 10-16-2003, 11:07 PM   #3 (permalink)
P10 Geek
yup! Sure sounds like it!
Brandon
'02 Maxima SE 6MT
'96 G20 (SOLD)
Old 10-17-2003, 09:26 AM   #4 (permalink)
timming
check again to make sure you havent skip a tooth.
alex29
alex29 is offline   Reply With Quote
Old 10-17-2003, 05:15 PM   #5 (permalink)
You either skipped a tooth on the chain or your idle rpm was too high when you were setting the timing.
99SE-L is offline   Reply With Quote
Old 10-19-2003, 01:05 AM   #6 (permalink)
A tooth was NOT skipped on the timing chain. It is exactly 20 links inbetween the two timing marks. What else could be off?
