Old 10-26-2003, 03:43 PM   #1 (permalink)
Clutch question
My clutch is very hard to push in and makes squeeking noise when I do. I was wondering if this would be as simple as replacing the clutch cable or maybe the throw out bearing would need to be replaced. Any thoughts or suggestions?
Thanks,
Jason
93NXShark is offline   Reply With Quote
Old 10-26-2003, 03:48 PM   #2 (permalink)
Coropate greed hater
Sounds like a two-fold problem, i.e. clutch cable AND clutch. The squeaking is classic of the t/o bearing going bad. You should replace both cable and clutch soon.
