When you mean cracking, do you mean, cranking? Does it do that all the time, or does it do it only when its hot/cold? If its not starting right, it does mean something needs fixing, but you need to provide more details.
If you stepped on the gas and it started, that could mean its not getting gas. It could be due to a clogged fuel filter, bad fuel pump or clogged fuel line. Can't tell you for sure until you add more details.
-The Usual Suspects
