It's funny that you post this, as I am having the exact same symptoms on my B15 front drivers side wheel. I have checked everything to see what is making the darn noise. We took apart the caliper and greased up the pad brackets, sprayed lubricant into the tie-rod boots, inspected the cv joint and axle. All this and it still cannot be found. I think its the wheel bearing but when I shake the tire when its jacked up there is no play. I am taking off my coilovers this weekend, maybe they are the cause (I doubt it).
Anyways, if anyone has any input, I'm also interested in hearing it.
