Old 10-30-2003, 08:04 PM   #1 (permalink)
1991 se-r engine flooding
appreciate any info anybody can give me. i just purchased a 1991 ser for a couple hundred dollars for a parts car. the body is dented up in several spots but not really bad and everything is on car so im trying to see if i could get it running. the car turns over good but just dont want to start, it is flooding really bad just soaking spark plugs with gas. ive checked the spark at spark plugs and its really good. going to check compression tomorrow to see how that is. if anybody can give me any help it would be greatly appreciated
peanuts se-r is offline   Reply With Quote
Old 10-30-2003, 08:11 PM   #2 (permalink)
Dreamin' of VVL
Did you try putting the pedal to the floor while cranking to get it started?
johnand is offline   Reply With Quote
Old 10-30-2003, 08:47 PM   #3 (permalink)
yeah, also pulled out fuel pump fuse and tried with pedal to floor but nothing. it sounds like its going to start up but just wont
Old 10-30-2003, 08:51 PM   #4 (permalink)
shift_boost
$100, its the fuel injector o rings go to the dealer they are lik 1.50 each buy all eight.
myspace
95 chevy dually big, black, low, and diesel
twisted200ser is offline   Reply With Quote
Old 10-30-2003, 08:53 PM   #5 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
I know this may seem dumb, but make sure the spark plug wires are all connected in the right order...
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
Old 10-30-2003, 09:10 PM   #6 (permalink)
yeah i have the wires running just like i have on my 92 se-r so there alright. anything special i have to do when replacing the o rings ? i will pick them up tomorrow. really appreciate all the help
Old 10-30-2003, 10:06 PM   #7 (permalink)
shift_boost
put some lube on them before you put them in. ha ha lube
Old 10-31-2003, 09:44 PM   #8 (permalink)
Try the MAF sensor from your 92. Recheck timing(crank and dist. rotor at #1) is aligned properly.<-1st 2 things I would try.
Chris M
Va Beach, VA
91 Classic Turbo
93 NX2000-work in progress
Projnx2000 is offline   Reply With Quote
