Old 10-31-2003, 02:57 AM   #1 (permalink)
Off-Topic lurker..
AAC valve install tomorrow.
Err, actually, I guess it'd be today.
My 1993 NX2000 w/ 224,000 original miles has the dreaded cold idle problem. Yes, she hesitates a little bit when the engine temperature is cold. I have acquired a 1998 Sentra SE AAC/IACV and I am going to attempt to install it tomorrow on my NX. I will have pictures and a write-up for all you nerds to look at after I'm finished. It won't be too hard. I figured it's easier to just acquire a newer AAC/IACV rather than clean my existing one, since they both look the same. In other words, I believe a highport and lowport AAC/IACV are interchangeable. I'm also going to do a fuel filter, and I might get excited and do a compression test while I'm at it. Anyone got any helpful hints/tips for installing an AAC valve on a highport SR20?
Well, I'll give you guys some updates tomorrow. I won't be using a new gasket....just some RTV in place of a gasket. Anyone think this will cause a problem?
-TIA
silversx is offline   Reply With Quote
Old 10-31-2003, 02:58 AM   #2 (permalink)
Off-Topic lurker..
BTW, thanks to Mike Gosselin for giving me a good product. I'll let you know how it works. Thanks again!
Old 10-31-2003, 01:42 PM   #3 (permalink)
NISSAN ADDICT
RYAN_S-14's Avatar
Trader Rating: 20 (100%)
good luck i want to hear if this fixes your hesitation..
the rtv should be fine as well i had rtv gaskets all over my 180sx
RYAN_S-14
WWW.FLORIDASR20S.COM
RYAN_S-14 is offline   Reply With Quote
Old 10-31-2003, 04:26 PM   #4 (permalink)
Yeah let us know how it runs after you clean it. I'm about to clean mine too once I finish making my own phenolic gaskets and polishing the IM
99SE-L is offline   Reply With Quote
Old 10-31-2003, 08:18 PM   #5 (permalink)
Off-Topic lurker..
It's done!
http://www.sr20forum.com/general-sr20/59323-98-aac-valve-install-compression-test-%5Bpictures-inside-%5D.html
