I need schematics for the parking lights. My front driver side parking light is out. Yes I’ve checked the bulb. I’ve switched it with the known working bulb on the passenger side. I’ve also switch the socket part of the light. It’s still not working.
Here’s the weird and strange thing. I have voltage. I’ve checked and there’s voltage there but there’s no amperage there. There’s a loose connection somewhere I just don’t know where. I need a wiring schematic to locate where the wiring branches off from and goes to the light.
If there is a voltage, then there must be a current when it is bridged to something. Take out your other corner bulb and place it there. Also make sure it is grounded. You can check whether it's a valid ground by testing with a digital multimeter.
I've done that, put in the other bulb. I know I have a good ground because the turn signal light on the same corner works. And I've learned through my work that just because you have voltage doesn't mean you have current, there can be a bad connection that you can't draw current through but you can still see voltage with a voltmeter.
