Old 11-01-2003, 07:11 AM   #1 (permalink)
SR20 Worshiper!!
Will my current ECU work...?
Hi...
I have tried to do a search on this one but havn't had much luck so here goes...
I am about to swap my SR18DE to an SR20DE all JDM, and wanted to know if my current ECU would work/adjust properly or if I would have to get an SR20DE ECU from a Pulsar/Primera etc...?
I have an Apexi SAFC so could adjust things that way...?
Help i'm as stuck as a very sticky thing...!!!
Kim.
SR18DE Pulsar is offline   Reply With Quote
Old 11-01-2003, 08:19 AM   #2 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Originally Posted by SR18DE Pulsar
Hi...
Kim.
Your SR18DE ECU will work fine. You will not need to change anything. The MAF will read all the air going into the motor so the fuel mixture will be fine. Stop having a heart attack over the situation.
Old 11-01-2003, 08:33 AM   #3 (permalink)
SR20 Worshiper!!
Thanks for the advice, at least I don't have to find one now...!!!
kim.
