couple easy ways to check, one is to look at the tranny, the lsd is a huge bulge out of the housing compared to the non lsd tranny, two is that the code says v, everything i have read indicates a vlsd tranny with that on it. three, jack up the front of the car, spin the tires, they should both rotate in the same direction with a vlsd, an open differential would make the wheels spin the opposite direction of each other. hope that helps
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
