Old 01-12-2004, 06:11 PM   #1 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
brembo rotors
can you turn the brembo crossdrill/slotted rotors? i need to change my brakes so i want to c if i can before i buy new ones.
adam
91 se-r
SR20 91 SE-R is offline   Reply With Quote
Old 01-13-2004, 08:14 AM   #2 (permalink)
GA13's Rock!
Adam,
check first if your rotors are already worn out and out of spec, also check the chamfering on it (there should be angles cut into the cross-drilling, if these are worn off, it might be time to replace the rotor, also check for stress cracks around the holes.
If the Rotor is not warped and you do not see uneven wear in your pads, do not get the rotors turned, just get a nice grit sandpaper and just sand the surface of the rotors gently.
i usually toss crossdrilled rotors once the chamfering on the holes is worn-off
I am currently here in the Phillipines, hunting for Nissan aftermarket surplus parts, how is the sunny grill holding up?
Tevs
Sunny is offline   Reply With Quote
Old 01-15-2004, 08:11 PM   #3 (permalink)
JDM BOOST WHORE
Originally Posted by Sunny
Adam,
Tevs
thanks tevs, the grill is still looking good. i get alot of compliments on it. i finally got all the badges to. and i put the mazda lip on it looks sweet. i plan on takin some pics so u can check it out. when u coming back?? u take your car with you to??
adam
Old 01-16-2004, 05:48 AM   #4 (permalink)
GA13's Rock!
I should be back Stateside in 5-6 months time.
I wish i could bring the SE-R's with me so i can kick some Honda Punks over here, these guys running around in 1.3, 1.4, 1.5, 1.6 liters think they are the sh*t. This place is crawling with Ricers
Take care bro,
Tevs
Old 01-16-2004, 08:17 PM   #5 (permalink)
not my president
does brembo make calipers for our cars?
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
