Old 01-12-2004, 11:28 PM   #1 (permalink)
not my president
hardend steel blades?
do they make special blades to cut hardend steel? need to know asap
thanks
jeff
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 01-12-2004, 11:41 PM   #2 (permalink)
My Ass, your face
vladha's Avatar
No luck at home depot, eh Jeff?
Jeff is using a Sawzall to cutt the hardened steel bolts that are holding his rear control arms in. They will not pull or pound out for anything. I even tried using a drill out kit... no luck. If he can get the bolt cut, he can get his bent control arms off and be a whole lot closer to having his car back on the road.
The bolt spins, but is slightly bent so it will not pull out... thus the need to cut them.
Somebody out there has got to know what kind of blade will cut through the bolts... please. He's busting his ass and this is the one thing that is holding him up.
Later,
Mark
vladha is offline   Reply With Quote
Old 01-12-2004, 11:58 PM   #3 (permalink)
in^3,N20,RPM,PSI
Get a WHOLE bunch of those dremel rotary cutoff wheels and keep swapping them in until you cut that thing off... Best if you have the Dremel at high speed and cut a little bit at a time!
95 240SX SE
James is offline   Reply With Quote
Old 01-13-2004, 12:03 AM   #4 (permalink)
For Sale
Carbide
1996 200SX SE-R w/ Stage II F-Max Turbo For Sale. Original owner and all work performed by yours truely. Looking for a good owner, accepting resumes now.
vrux is offline   Reply With Quote
Old 01-13-2004, 01:03 AM   #5 (permalink)
not my president
carbide blades...sounds expensive ill get 6 i burned the other blades up with in seconds of using them
Old 01-13-2004, 07:45 AM   #6 (permalink)
fartin dust
Die grinder and a cutoff wheel will cut anything.
I used to be a noob but now I'm just a dumbass
www.m4exhaust.com
james vick is offline   Reply With Quote
Old 01-13-2004, 01:37 PM   #7 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
That would be my recomendation as well. If your still having trouble, heat that bolt up red hot and let it cool slowly, that will take the temper out of the bolt and make it softer.
Old 01-13-2004, 08:16 PM   #8 (permalink)
My Ass, your face
vladha's Avatar
I don't think it's possible to use the Dremel, not enough room and that's with the extension. You have to remember how small the dremel and it's wheels are and it's not aligned to go after a bolt in that position. Also, there is no way, even with my more powerful dewalt tool that it will ever cut through that bolt... it's not made for that.
Heating the bolt red hot to change the temper is a good idea... except it's still on the car. I'd be extremely worried about something else getting over heated.
Later,
Mark
Old 01-13-2004, 08:27 PM   #9 (permalink)
Professor Dingbat
Did you try heat? I know ive mentioned this before but i have done this before and many other things that seem impossible to come loose free up very well with heat.
Old 01-13-2004, 09:53 PM   #10 (permalink)
Old School
You can get a carbide hack saw blade (cheap) and cut it with tin snips to fit in the sawsall. I used this trick to cut the hardened rear spring shackle bolts in my 64 1/2 Mustang.
Lew
lshadoff is offline   Reply With Quote
Old 01-14-2004, 02:07 AM   #11 (permalink)
not my president
ok i got 5 bucks to spend to get the blades i need maybe 5 fingers to i dont know ill let everyone know tomorrow i hope 5 bucks is enough....heating the bolt up at jims house tomorrow and cutting the bolts off at my house tomorrow
