I did a search and didnt find what Im looking for. I will be doing a mild port and polish on the head.
Question: What type of valve spring compressor do you guys use when removing the valves? I picked up an overhead type from Sears and its truly a PITA to use. I highly doubt Im going to be able to get the valve assembly back in with this tool.
You might be able to find a set of compressors that hold the valve from below and compress the valve from the top. I know AutoZone has this tool for rent. I ran into the same problem, and just let the machine shop do all the work.
1991 Sentra SE-R
check out www.northerntool.com and do a search for valve spring compressers i am in the process of swapping mine to i ordered one from them yestereday i am just waiting for it to come in, it was like 60 bucks, also a few of the styles wont work on our cars if you have the head off the car then you can use the type that looks like a C-clamp and it wont be hard but if its on its another story.
Thanks for the link, that universal one looks like it will do the job. I was planning on building one similar to that, but for $60 it may not be cheaper to build one.
let us know if that tool works out for you....I have my head off and want to swap out the springs with some Greddy springs..and maybe reddo the guides/seals...but im kinda hesitant to try and dissasemble the valvetrain 1st because ive never done it and 2nd because im not sure ill have the right tool....
~jRod
Originally Posted by Random Genius
"...Everyone in California is easy to deal with, in the mid-west people are so uptight and their first reaction is to get pissy to try and get results. Makes me want to move to California!..."
