Right now I'm seeing 180-185ºF while cruising. If I'm stopped (like there's an accident on the way home and the freeway turns into a parking lot with street signs) then it'll go as high as 210 or so. But it also really just depends, with the DET I'm sure you'll be a bit higher than I am, but right now while it's cool out, the cooling system isn't being used all that hard. It's takes quite a while in the morning for my system to warm up, and it's really not even that cold out either
You'll also realize how innacurate the stock gauge is, your water temp will vary quite a bit and the stock gauge never moves...
