Old 01-16-2004, 09:45 AM   #1 (permalink)
Struts
My 92 Classic is completely stock. After 194K miles, I imagine that new struts are long overdue. The car drives and handles fine with no visible leaks from the struts. Is this an easy job? Should I wait until the car starts hopping?
ron92ser is offline   Reply With Quote
Old 01-16-2004, 03:46 PM   #2 (permalink)
merely a flesh wound
chriscar's Avatar
Moved to Technical
Old 01-16-2004, 03:49 PM   #3 (permalink)
Coropate greed hater
Do it whenever you want to. I changed my springs and re-used my stock struts as they weren't bad. The only reason I changed my springs was because the stock spring on the front driver's side was rusted so bad that it broke into two pieces on the the bottom portion.
The fronts aren't that hard to change. Its the rear ones that I hated doing. You have to take out the rear seats to get to the bolts that hold the struts. Other than that, I don't think you'll run into any hassles. Do get an alignment right after replacing your struts.
All this should take you about two hours if you have the right tools.
-The Usual Suspects
Old 01-16-2004, 08:16 PM   #4 (permalink)
not my president
im lucky, my rears are easy to change, but you can replace them when ever.
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 01-17-2004, 09:43 AM   #5 (permalink)
Ron,
After 194K you owe to you and your car to put 4 new struts on the old girl. You could go with KYB AGX if you wanna spend the cash or go with KYB GR2 if you dont. I really doubt the struts are doing much after that kinda mileage. You say it handles fine...but after you put the new ones on youll be like....WOW what a difference.
Terry
92 Classic...Too many goodies to list...Newest: Disco Potato Turbo.
tgvince is offline   Reply With Quote
Old 01-19-2004, 02:35 PM   #6 (permalink)
Thanks for the info. The car does make a little racket when I cross RR tracks, etc. I'll check into it.
