Old 01-17-2004, 12:36 PM   #1 (permalink)
The road's my slave
brake difference?
Sorry to bother you with another brake question, but i was just wondering what the difference between regular sentra brakes and se-r brakes are? i have and nx2000 but i think that the previouse owner installed the wrong brakes. how do i know if when i get new brakes, i wll be getting the right size?? any part numbers?
ChrisNX2000 is offline   Reply With Quote
Old 01-17-2004, 01:53 PM   #2 (permalink)
The SE-R has bigger brakes then the regular sentra. The reg sentra also has drum rears, and we have disc. Your NX2k has even bigger brakes then the SE-R. The rotor is alot thicker. Search for "ad22" and you should be able to find the dimensions of the rotor and measure yours to see if its correct.
-Mike
Old 01-17-2004, 02:33 PM   #3 (permalink)
The road's my slave
thanks Mike, but does anyone have any specific sizes?m or measurements?
Old 01-17-2004, 03:49 PM   #4 (permalink)
I searched for you and found it. They should be 257mmx26mm. Most places have the nx brakes listed wrong and when you order them, you get the smaller se-r one's. If you search you will find tons of info on it, including part numbers to make sure you get the right stuff.
Old 01-17-2004, 07:00 PM   #5 (permalink)
The road's my slave
thanks man! i got the measurements myself, but thinks for the help. you my car had se-r brakes, or maybe even sentra brakes.
Old 01-17-2004, 08:09 PM   #6 (permalink)
Coropate greed hater
Looking at the numbers etched on the calipers, SE-R calipers should say AD18VF and the NX calipers should say AD22VF.
-The Usual Suspects
Old 01-18-2004, 04:02 PM   #7 (permalink)
The road's my slave
hmm, if i wanna get the stock brake kit or stock rotors for the NX2000, do i have to order them from coutesy nissan? or can i get aftermarket rotors, such as the brembo one that fit all NX2000 w/o ABS?
Old 01-18-2004, 04:05 PM   #8 (permalink)
Professor Dingbat
That's another screw-up. Order the ones for NX2000 with ABS. Last year I worked at a parts store, and it was really hard to try and tell my boss all of the listing were wrong....even though I owned three NX2000s, 2 with ABS, one without and they all had the exact same front brakes.
Old 01-18-2004, 04:26 PM   #9 (permalink)
The road's my slave
so it's ok to get the brembo rotors as long as they are the ABS ones. BTW, my NX2000 is w/o ABS
Old 01-18-2004, 04:30 PM   #10 (permalink)
Professor Dingbat
yep. Order the ones for NX2000 with ABS. Unless someone has changed your entire front brakes (pads, rotors, calipers torque members) to something not original, it will fit.
Old 01-19-2004, 02:42 PM   #11 (permalink)
The road's my slave
are there any bremebo callipers, brake lines, or pads for the NX or should i just stay with my stock ones?
Old 01-19-2004, 02:47 PM   #12 (permalink)
You said your car has sentra brakes? If so, you need calipers too, or the nx rotors will not fit. brake lines are the same. You can get some nice stainless steel braided ones for around $100. Calipers shouldnt really matter. Call up matt (maddmatt) at carbotech for some nice brake pads. Tell him your a forum member for 10% off.
-Mike
Old 01-19-2004, 02:58 PM   #13 (permalink)
The road's my slave
oh, hey mike, i guess everything in my brakes is NX like the callipers, i just need new rotors and there in lies the problems, so now i'm getting bremebo, hopefully the measurements are correct and they will be ok for my NX callipers
