Old 01-18-2004, 09:48 PM   #1 (permalink)
s13 frankenstein
Car Starting Issue: UPDATE ....
well, the car will try to actually start up a bit if i pull the fuel pump fuse and spray some carb cleaner into the TB, but if i hook the fuel pump back up , it wont even come close, it will just crank over and over again like it did before. Any suggestions why it would not even try to work with fuel pump hooked up?
i'm really out of ideas here...
93 Nx2000 SR20DE+T - Parted out!
93 240sx SE Coupe - "Stock" and slow...
Witt19 is offline   Reply With Quote
Old 01-21-2004, 01:31 AM   #2 (permalink)
They're just cones!
It's almost definately the fuel system then. Try different injectors/rail, new fuel filter, maybe even a new pump if you have one.
Matt
Boosted as of 11/15/05
Driven97 is offline   Reply With Quote
Old 01-21-2004, 02:06 AM   #3 (permalink)
Professor Dingbat
probably a pump. the injectors would not fail all at once. Plus fuel pumps are a common problem, especially if youve been pushing it hard by boosting it.
Old 01-21-2004, 08:25 PM   #4 (permalink)
s13 frankenstein
hmmm, its a relativly new walbro pump, and it still whirrrrrs, i dunno, i'm gonan throw a fuel pressure guage on it soon though and we'll see how it looks...
