Old 01-30-2004, 05:39 PM   #1 (permalink)
Brand new temp sensors now what?
Fans still run all the time after replacing temp sensors
but the temp gauge reads correctly, YAY!
I also tried swapping relays around, that was not the problem
I don't know what else to check, could it be my ECU, or maybe the wiring
Am I going to have to go to a dealer now?
What it does:
I will not be able to retest the cold start untill tomorrow, but this is what it was doing
Cold starts, have to give the car gas to get it going, and will often die untill warmed up
after warming up it will still often drop the revs to 500rpm or below, and almost stall out
This I have been able to test:
idle changes from stop to stop, sometimes its at 850, other times at 1200 or anywhere inbetween. This is after the car is warmed up
fans run non stop all the time
there is no air in the system that i know of(heat blows hot)
car has:
New T-Stat
New water pump
New O2 sensor
Cleaned AAC during motor swap
re grounded MAF
new temp sensors, both gauge and ECU
the car had none of these problems before the motor swap
Please help, I have benn having these problems since the swap and this is my daily driver
EDIT: I revised this!
1993 Nissan Sentra SE-R
Soko motor, OBX header, HKS exhaust, clutchnet fibercarbon
focalBlur is offline   Reply With Quote
Old 01-30-2004, 06:37 PM   #2 (permalink)
You like that, dontchya?
Test for continuity at the harness for your water temp sensor. If you don't have continuity, reground the wire and see what happens.
Antonio G.
BLACK 91 SE-R w/ DET, 7psi - 13.9@101.9 on streets, 206whp/196wtq
WHITE 91 SE-R for daily driver action
AntonioG is offline   Reply With Quote
