Old 01-30-2004, 07:50 PM   #1 (permalink)
weird cam timing problem-ticking me off
well i tore down my motor due to valve and timing chain noise.put on a new timing chain and tensioner and guides.when i tore it down i noticed the timing chain was not lined up properly.well i put the new chain on andlined it up correctly-gold links matched dots on gears and the intake was at 10 and exhaust at 12.put it all back together and it would not start.checked some things nothing.finally did a compression test 40 psi.ended up moving the chain link by link till it would run.finally it runs but why won't it run when it is all lined up right.it doesn't make sense to me.and if i can't figure this out i am junking the motor.can anyone help?
b13racer is offline   Reply With Quote
Old 01-30-2004, 10:11 PM   #2 (permalink)
VE powered
When you tore it down did you remove the front cover and make sure the chain was also matched up with the gear on the crank?
autoxer7 is offline   Reply With Quote
Old 01-31-2004, 04:04 AM   #3 (permalink)
yes i did.i lined up all the gold links with the dots on the gears.
Old 02-01-2004, 04:34 AM   #4 (permalink)
"Pimping aint Easy"
is the cam aligned right itslef?
Bust some knuckles, Leave some Blood and Skin!
http://home.comcast.net/~jjvphotography/susuki.jpg
1993 SE-R Gone to a good Home.
Still drive a volvo
and when its not raining a BIKE
Dropped89 is offline   Reply With Quote
Old 02-01-2004, 04:43 AM   #5 (permalink)
yeah everything is lined up correct.i have decided to not waste any more of my time on it and just buy a jdm.
Old 02-01-2004, 04:45 AM   #6 (permalink)
"Pimping aint Easy"
just go det dude
Old 02-01-2004, 04:51 AM   #7 (permalink)
i already have a t3/t4 setup.i had this motor built 1 year ago and have had nothing but problems with it.i'm just going to buy a de and put my setup on it
Old 02-01-2004, 10:44 AM   #8 (permalink)
"Pimping aint Easy"
oh ok gotcha, cool wel i hope all goes well.
I have found out that after buying this ser ive had nothing but problems aswell.
im sicking fo fixing crap on it!
