Okay, last week i rolled my window down just minutes after starting my car up and it wouldn't roll back up... both sides wouldnt move. But after driving for a few minutes it finally rolled back up again and worked fine. A few days later the same thing happend, except for now they wont roll down anymore (glad they got stuck up instead of down...) Anyone know what could be wrong? why would both sides just stop working?
This happened to my NX like a few days after I bought it. I left it with the windows done for a while, and they went back up. That was 3 months ago, hasnt done it since.
__________________ Serban - EEN President/Founding Father
if its making a noise.. the motor is most likely gonna go.. if it doesn't, it's most likely the window switch
Missing my sr20 b14, but still showing some love. Possible new project when I return!
Old car: 1999 Sentra SE-L Turbo: USDM sr20de, t25 turbo, hot shot intercooler kit, BIG ass fmic, nismo fpr, autometer fp gauge/boost gauge, mbc set at stock boost for now! 7psi= more traction>11psi=less traction.
well its not the motor, it doesnt make noise just simply doesnt work sometimes. But why would both switches, on passenger side too, not work at the same time? Well, hopefully this will stop soon like with Fast91SER's NX. *** its annoying as hell! they still worked tonight so hopefully...
Okay the drivers switch is the master switch if it is doa then the pass will not work sounds like eather a wire broke or the switch is not making contact all the time. If its a wire it is most likely in the pillar area and won't be very visable to test this open the door and while operating the switch wiggle the wires in the pillar boot. HOPE this HELPS!
thanks Cloud, if it starts up again I'll check into that. So far its been working fine though
how troublesome.
