Old 02-01-2004, 03:57 PM   #1 (permalink)
Stalling, shutting off, hard start... HELP!
So I have these 3 problems going for me. First, in the mornings, the idle is very irratic. It'll start going up and down,up and down. Then when I throw the car in neutral, it'll shut off on me when I get to a complete stop. AND while I'm normally driving the car (especially on the freeway), it'll stall REALLY bad. Start choking pretty bad. Everytime the car shuts off, I have to give it gas to start it up again. I already changed the fuel filter, but didn't seem to do to much of a difference. From reading an earlier post, seems like my AAC valve, but I don't have too much background about the AAC valve. Any suggestions??
Thanks,
Gino
-1991 VE'd P10, aka Griselda
-1992 B13, future track slut, aka Perlita
gTeknikal is offline   Reply With Quote
Old 02-03-2004, 07:17 PM   #2 (permalink)
NO ONE can help me out with this?
Gino
Old 02-03-2004, 07:43 PM   #3 (permalink)
I hate 240sx owners
i kinda have the same thing in my automatic. i tried just about everything today, and on the way home it nearly stalled on the busiest road in town in rush hour traffic. AGAIN! i think its my alternator though, and theres not enough juice going to the ECU, cause my radar detector said the voltage was just a hair under 12V when it thought about stalling. as long as i kept the revs up the voltage stayed up around 12.9 and i was able to make it home.
Raze: To destory, demolish, obliterate.
Project RaZe: The ongoing effort to destroy, demolish, and obliterate the competition.
RWD SR20DE 93 240SX Coupe.
Best all Time Quote:
FWD should really be spelled FTW
NissanTuner is offline   Reply With Quote
Old 02-03-2004, 08:09 PM   #4 (permalink)
I can spell you.....
Good luck buddy I've been trying to find a solution to my stalling problem for over a year now Mine is a cold engine prob though, but otherwise sounds very similar.
Read my thread for a list of things I've done/replaced but have not worked.
http://www.sr20forum.com/sr20de-technical-corner/58802-video-my-car-stalling.html
Wishing I could be topless all the time......
Out with the old:
http://cardomain.com/id/chucky200sx
In with the new
http://www.cardomain.com/ride/2138722
chucky200sx is offline   Reply With Quote
Old 02-04-2004, 10:32 AM   #5 (permalink)
Have you tried cleaning your throttle body. Mine had the "stalling when you come to a complete stop after driving above 30mph" problem . Did just a minor clean-up of the throttle body and the problem was solved. New plugs and distributor cap/rotor didn't do much prior to the throttle body cleaning. Hope this helps.
BruHaHa is offline   Reply With Quote
Old 02-25-2004, 03:04 PM   #6 (permalink)
Re: Stalling, shutting off, hard start... HELP!
I will try this soon... thanks
raene is offline   Reply With Quote
Old 02-26-2004, 02:56 AM   #7 (permalink)
Thanks,
Gino
I would start by adding an extra ground to your maf, then check base idle (I always recommend this!), and also check your fuel pump pressure. If you are not sure about any of this- go to www.se-r.net it explains how to do just about everything.
Chris M
Va Beach, VA
91 Classic Turbo
93 NX2000-work in progress
Projnx2000 is offline   Reply With Quote
Old 02-26-2004, 10:45 PM   #8 (permalink)
IN GOD I TRUST
agree. def check your base idle and timing.
04 Spec V stock
02 VW Jetta 1.8turbo chipped, worked, and kickin ass
seRpwr is offline   Reply With Quote
Old 02-26-2004, 10:50 PM   #9 (permalink)
Car God
also try using some propane and look for a MONSTROUS vacuum leak. Spray around the intake manifold and listen for the idle to change noticeably. otherwise try some of the other solutions..hard to diagnose a car over the computer bud...take her to a shop or something../
1999 Altima SE-L Check Registry for pics! Updates soon for new lighting, intake, exhaust, and leather added...
Building a 1991 SR20DE ground up for "In-two-oh!" or "NAAWS!" (Nitrous Oxide) Pics soon of that, too!
Unnatural SR20 is offline   Reply With Quote
Old 07-23-2007, 02:34 AM   #10 (permalink)
Ironically, I was searching for this same exact issue that I'm currently having with my B13, and I had forgot that I had even posted this for one of my older B13s that I used to have!
So I'm pretty much having the same issues, with the stalling and the car shutting off everytime I get to a stop light. Throttle body has already been cleaned, and I just changed the fuel filter. I'm gonna check the base timing tomorrow per SE-R.NET instructions and am going to clean out the AAC. Anything else anyone has done to remedy this issue?
Old 07-24-2007, 05:38 AM   #11 (permalink)
For whoever is interested, I resolved my idle issue today. After cleaning out the AAC valve and setting my timing, no more dying out and no more hesitation!
I also went and checked the PAIR(AIV) via SE-R.NET instructions and there was no suction whatsoever from the port in the air box. So does this mean this unit is not working?
Although the car seems to be running pretty good right now, I still have my check engine light on and have yet to check the codes. I have no doubt that it is 02 related, especially since the prior owner seemed to have splied into the wiring and regrounded them for some reason. Let's see what I come up with.
Old 07-25-2007, 02:41 PM   #12 (permalink)
whats a sr20?
newb ?
what is the AAV valve?
91 ser: short shifter, sparco shift knob pedals steering wheel, aem WAI, greddy sp catback, timing, agx's, eibach springs, b14 wheels, jvtr header, ground kit
98 se: pop charger, timing, custom 2 1/2" cat back magna flow muffler, exedy stage 1 kit, fidanza flywheel, need a header and a high port intake cam
00 x-terra: 2 1/2" lift, 31s, air lockers, bumper
98se is offline   Reply With Quote
Old 07-25-2007, 03:38 PM   #13 (permalink)
build completed...
Trader Rating: 26 (100%)
Heh, I think he meant AAC valve...
SR20DEEP in TX
Old 07-31-2007, 03:05 AM   #14 (permalink)
Well, I'm back to my original problem again. The car had been running great for the past week, and today it started shutting off on my again, as well as the stalling. Could my AAC be going out?
To recall, so far I've:
-cleaned throttle body
-reground MAF
-cleaned out AAC valve
From my searching, seems like the next thing I should target is the EGR and timing, although I have no timing light. Where are the local guys at when a brother is in need???
Help me out here, people. It's bad enough I'm driving my car with rod knock, but now I have to turn it back on everytime the light turns green. Not fun...
