Old 02-01-2004, 10:59 PM   #1 (permalink)
rod and main bearing sizes
rebuilding my low port sr20se need to know where the bearing sizes are stamped checked crank, and block cant find the #'s would like to order bearings this week thanks
David
madmoney is offline   Reply With Quote
Old 02-01-2004, 11:29 PM   #2 (permalink)
stirring but plain-faced
On my DET they where on the crank counter weight furthest to the driver side. You may need to get a small mirror to be able to see into the space between the crank and the timing cover.
NoClassic is offline   Reply With Quote
Old 02-01-2004, 11:47 PM   #3 (permalink)
easy 400WHP
Trader Rating: 27 (100%)
as per the fsm you need the numbers from the first crank counterweight. The top row of numbers (5 total) is for your mains, [the row below that (4#s) is for your rod bearing grades] Then on the block where the aluminum oil pan mates there is another set of (5) tiny numbers. once you have the 2 rows of 5 you add them in columns.. should look something like 11111 & 12222
so in that particular instance you would need the following: #1- grade 2, #2-5-grade 3....if this aint clear enough i believe JWT's and/or SR20DEvelopment's site has that info for bearing selection.. hope this helps.. good luck!!!
~jRod
Originally Posted by Random Genius
"...Everyone in California is easy to deal with, in the mid-west people are so uptight and their first reaction is to get pissy to try and get results. Makes me want to move to California!..."
