Old 02-02-2004, 08:33 AM   #1 (permalink)
SR20DE conversion help!
Down here in Australia, i got my hands on a SR20DE engine, tranny, comp., loom, driveshafts, etc! Anyway, ive got a 87 Pulsar, 1.6 single point injection, and i turned the crank lobes blue, so i opted a conversion rater than a stockie! Its apparently an import off of a pulsar gti, fwd from japan, its got a grey rocker cover. There is absolutley no info over here, any would help! (Bolt tensions, all fact. specs, comp. ratios, gear ratios, etc). Thanks heaps!
spoolin is offline   Reply With Quote
Old 02-02-2004, 03:30 PM   #2 (permalink)
If you have a EXA you would need alot of fabracation for the mounts...here is a link on a sentra which isn't that much difference...http://www.nissanperformancemag.com/...smoproject.php Have you tried http://www.nissanexa.com They have info on the swap also.
Rocky
1991 B13 Se-r - JDM swap Finished 12-07-03, Goint Turbo Soon -- Opps Turboed 8-21-05, RIP 9-11-06
1984 DATSUN 300zx Z31 N/A - Just my Summer car,
1994 Nissan Sentra GXE 1.6 Econobox
RockyB is offline   Reply With Quote
Old 02-03-2004, 08:01 AM   #3 (permalink)
How much fabrication is alot? N do you know what these engines put out??
Old 02-03-2004, 01:18 PM   #4 (permalink)
Bitter Old Man
That engine is available in the NX, which is available in Oz. Whiteline has stuff for it, I think.
Also, check www.se-r.net for tonnes of info.
Bruce in Houston
RIP swwwinger
Old 02-04-2004, 09:21 PM   #5 (permalink)
You would have to fab. a driver side mount(pass. mount in US). The trans. mount you have to drill thru the body to attach it like the E15. The front and rear you would use the sub frame crossmember and use/re-locate the mounting holes. Just make sure everything is leveled and possitioned correctly in the engine bay.
Rocky
