Old 02-02-2004, 10:59 AM   #1 (permalink)
Cooling fan not working!!
Hi guys.
Let me put it this way, the fan doesn't start until I turn on the A/C.
I've heard many opinions but no one had worked.
I've already done or changed this: thermostat, radiator cap, drained the coolant and made all by the book.
At the auto part they told me it could be the coolant sensor, but i want to be sure that it is because, I don't wanna keep spending money without seeing results.
thanxxss
1993 Sentra SE-R
Mods:
->HS Header->HS WAI/pop charger->ACT HD PP->2.25 exhaust->tuned ECU by JRios
153 whp
132 ft-lbs tq
http://memimage.cardomain.net/member...14_37_full.jpg
ralphy SE-R is offline   Reply With Quote
Old 02-02-2004, 11:42 AM   #2 (permalink)
try disconnecting the pigtail to the coolant sensor when the car is on, i'm not sure if that sensor is set up to complete the circut or to close it, but if that sensor is bad there is a 50% chance that the fans will start up when it is disconnected. god, i wish i had your problems, i can't imagine my car overheating anytime soon being up here in cold ass ohio
T.S.O.L.
cause4alarm is offline   Reply With Quote
Old 02-02-2004, 01:55 PM   #3 (permalink)
Thanks man!!!
I really need the car to be as cool as posible because here in Puerto Rico the climate is very hot
Old 02-02-2004, 03:50 PM   #4 (permalink)
Trader Rating: 41 (98%)
Coolant sensor bad...
Looking for a cheap SR20 mechanic in the NYC area, or a garage w/ Tools... PM me.
Erikbronx is offline   Reply With Quote
Old 02-02-2004, 11:18 PM   #5 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
Ditto, coolant sensor. There are two of them, do a search to see if it is the 2-wire or single wire. I THINK the two wire is the ECU temp sensor, the single wire is the gauge.
Old 02-03-2004, 05:42 AM   #6 (permalink)
Learn to swim
You are correct...Josh
-Bill Hicks
UNDRCOVR is offline   Reply With Quote
