Old 02-02-2004, 03:07 PM   #1 (permalink)
Fidanza flywheel + check engine light
Last Friday, I had my mechanic install a Fidanza lightened flywheel along w/ an ACT clutch. I got the car back, and after about 10 seconds of driving I get a check engine light. I take the car back to the mechanic and it reads out as the crank sensor. I ask my mechanic what the deal is and he says that a lot of steel flywheels have a magnetic part in the flywheel that is used by the crank sensor to read the flywheel. As a result, the sensor is freaking out because the flywheel is made of aluminum rather than the stock steel flywheel. The car runs great but I've never heard of people having this problem. Any comments? Is my mechanic on crack and just forgot to reinstall the sensor? I'm trying to get ahold of Fidanza to see if they know anything.
zeno is offline   Reply With Quote
Old 02-02-2004, 03:17 PM   #2 (permalink)
Coropate greed hater
http://www.sr20forum.com/showthread....ht=CEL+fidanza
-The Usual Suspects
Old 02-02-2004, 11:20 PM   #3 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
It's been covered a million times, the light is just as your mechanic told you.
No big deal, pull the lightbulb and enjoy the flywheel, or just ignore it.
Old 02-02-2004, 11:43 PM   #4 (permalink)
love the Florida sun!!
sounds like you got a B14....ditch it and find a B13...Fidanza=no code LOL
94 Sentra SE-R, 10:1 Red Top SR20DE, ! 15.652 @ 87.34 mph....***Dead***
R.I.P SR20forum.com
94sentraSER is offline   Reply With Quote
Old 02-03-2004, 12:15 AM   #5 (permalink)
Wants Primera Race Motor
or get a better jun flywheel:p
Brian
My SE-R
14.5@ 94 all motor
click for my DET install
12.5@ 114 boosted 295 whp 298 tq
BlkB14 is offline   Reply With Quote
Old 02-06-2004, 11:14 AM   #6 (permalink)
master of nothing
Trader Rating: 18 (100%)
jun rule's
97 200sx SE,electric water pump, GT35R,PROTECH equel lenght manifold,
stage v portedhead, ferria over sized valves ,je 10.4.1, cunningham rods ,total seal rings ,a1000 aeromotive fuel pump ,96lb injectors, o2 stage 2 ,Q45 t/b (90mm)
jun flywheel,clutch net pp with 4 puck ,3in exhaust,,jwt brain,PAR SYNCRO set,welded case
spearco ,kyb,S3,46mm tial,
muleman is offline   Reply With Quote
Old 02-06-2004, 04:49 PM   #7 (permalink)
Old head
Hell w/ what they say, just replace the damn sensor. Very easy to do.
man...since 2001 dizam I'm old.
John Doe is offline   Reply With Quote
Old 02-06-2004, 04:57 PM   #8 (permalink)
rollin 4 deep with JoeD
^^^^ NO. Replacing the sensor wont fix anything.
The car will run just fine, don't worry about it.
Frank Orozco
cnynracer1 is offline   Reply With Quote
Old 02-08-2004, 09:18 PM   #9 (permalink)
drive the dam car and have fun
jus-SER-luv is offline   Reply With Quote
